Cast Iron Radiant Baseboard
Robert_10
Robert_10 Member Posts: 1
Need to shorten a 16ft length of cast iron baseboard. Seams are apparent in two foot sections. Looking to remove an interior 2ft panel. End panel needs to re-joined to remaining in order to pipe back into system. The manufacturer is American Radiator & Standard Sanitary Corp. The model radiator is "Radiantrim Panel". Unit is original with home built in 1951. Can provide photo if necessary. Advice greatly appreciated.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Look in the Library under \"Radiators.\"
    You'll find the installation manual there. If you like it, buy a brick! ;-)
    Retired and loving it.
