Backflow bypass
Donny
Donny Member Posts: 37
Any RPA members out there have a problem with the article "Pressurization of Closed Hydronic Systems " in the March 2004 Radiant Panel Report? Figure 3 shows a bypass line plumbed in upstream of the makeup water supply valve going around the backflow device, press red valve, and connecting downstream of the isolation valve. I feel the proper location of the supply side of the bypass line should be downstream of the backflow device.
