Familiar Question
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
from architects, builders and homeowners:
"I have a small (450 [])addition that I want to heat with radiators; can we use the existing Takagi "flash" domestic water heater and a heat exchanger as the heat source for the radiators?"
For various reasons, radiant floors and/or walls are not options at this point.
My fear is cranking the Takagi up to 180° may scald someone (tempering valve failure). And even at 180°, you're only going to get 150-160° on the secondary side of the heat exchanger; just means bigger radiators.
Any of you guys do this regularly?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
You could
turn that low mass low water content into a large water content heater. Add a Thermox indirect which carries boiler water in the tank and supplies the DHW with the coils.
Although I know in some of your areas double wall HX's are required??
This way you would lower the dhw temperature a bit and give you a nice buffer capacity, to minimize short cycling with a small, mild day loads on the heating side.
I use the Sparco thermostatic (scald guard)and they, like many others, always fail to the cold side. Scalding should not be an issue.
Will the Takagi run up to 180°? Some of those small instantanous types limit out at 140 or 160°.
hot rod
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
