Dry contacts
Tim_15
Member Posts: 8
What are dry contacts on a heat timer. Can an electrical source flow through them from a limit control.
\"Dry\"
means they are not energized; it is a switch and will close on a call for heat to enable another device (boiler, relay, pump, etc.) and the manufacturer will usually rate the maximum load, i.e. 220 volts, 6 amps.
Not powered
If your limit control passes through any current then seperate the dry contact side with a relay. The dry contact is only a switch and may not have any power applied. Enjoy...Dan
what model heat-timer and what is your application //////// B-B is your limit circuit wired in parallel with your aquastat its a dry contact you supply 1 side w/voltage0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
