DHW Mixing Valves
doug_10
Member Posts: 102
Does anyone have input on a mixing valve I can use on a 2 temp DHW system. The problem I have had is with a recirculation pump on the mixed water the valve does not seem to keep an even temp- Eb
Taco, 5000 series mixing valve
Joe Mattiello
Technical Service TechnicianJoe Mattiello
Taco Comfort Solutions0 -
Attached is a piping diagram that should help resolve your recirculation loop issues. Please advise, if you have any additional questions.
Joe Mattiello
Check out the Honeywell/Sparco
product too! Good stuff and no matter who's valve you use it will probably keep you out of court if you set it for under 120 F.
http://www.honeywellwatercontrols.com/sparcosdis/Mixing_Valves/SPARCOMIX_AM_SERIES_SDIS150_1016_1017_JUNE_01_2002.pdf0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
