tap a vent
Claude
Claude Member Posts: 8
I'm fixing a radiator my friend gave me to use in my kitchen. Unfortunately the vent is broken inside the tap of the radiator. What size tap do I need to purchase to retap the hole? Thanks.
  • air tap
    1/8 NPT(27Threads per inch, tapered) Use a 11/32 Drill.
    If you have to drill larger, tap 1/4NPT a(18 threads per inch, 7/16 Drill) and use a 1/4x1/8 Black Bushing.
    Steve
  • Robert O'Connor_7
    Robert O'Connor_7 Member Posts: 688
    Threads broken off inside?
    Why don't you just extract the old threads from the radiator?..Robert O'Connor/NJ
  • Matt Undy
    Matt Undy Member Posts: 256
    yes, use an easy out/screw extractor...if that doens't work then drill it out..much better and safer to just take out the broken piece if it will come.
    Matt
  • bob young
    bob young Member Posts: 2,177
    THREAD EXTRACTORS
    IF YOU USE AN EASY-OUT TO REMOVE A BROKEN AIR VALVE FROM A CAST IRON RADIATOR, YOU WILL BE LOOKING FOR A REPLACEMENT RADIATOR IMMEDIATLY.
  • Matt Undy
    Why is that? I'm not saying it isn't true, just if you say something like that without explaining why it doesn't help anyone much.
    Matt
  • bob young
    THREAD EXTRACTORS
    AN EASY OUT WILL MAKE A HAIRLINE CRACK IN THE RADIATOR TAPPING , YOU MUST CHOP OUT OR DRILL OUT THE BROKEN THREAD. DO NOT USE EASY OUTS ON CAST IRON OR YOU WILL NEED A NEW RADIATOR OR BOILER OR WHATEVER.
  • Robert O'Connor_7
    bob young.
    Did you have a bad experience once Bob? Been doing this since 1971 and haven't broke one (air vent tapping) yet. I have however malded a few and had to tap them, but most success comes with resonable skill and dilegents, and a little bit of patiences...Robert O'Connor/NJ
  • bob young
    EASY OUT----NOT
    MATTER OF FACT I DID HAVE A BAD EXPERIENCE IN THE EARLY SIXTIES WHEN I USED A COMBINATION TAP EASY-OUT TO REMOVE A BROKEN AIR VALVE. . FROM A RADIATOR FOR A JOB FOR MY BOSS. COST ME THE PRICE OF A USED RADIATOR [ ABOUT FOUR OR FIVE BUCKS IN THOSE DAYS ] BUT I DID NOT FORGET THE LESSON. OVER THE YEARS I HAVE REPLACED SEVERAL BOILERS WHERE AMATUER MECHANICS HAVE CRACKED THE IRON ATTEMPTING TO REMOVE BROKEN GAUGE COCKS ETC. IFB YOU WISH TO CRACK A RADIATOR --BE MY GUEST AND USE AN EASY OUT . IT MIGHT WORK ONCE IN A WHILE SINCE YOU SAY YOU HAVE DONE IT, BUT I MYSELF WOULD NOT ROLL THE DICE . I DO NOT LIKE THE ODDS. AND AFTER FORTY + YEARS IN THE TRADE I HAVE DONE MY SHARE OF RISKY STUFF, MOSTLY SUCCESSFUL. ALL I CAN SAY IS " BEST OF LUCK. "
  • Claude
    Home Depot had the tap and it worked for me nicely. I drilled it out with the 11/32 and then tapped it. The tap came out with the tread of the vent wrapped aound it like a spring. What do I use for paint? I don't care about color. Just wan to use the right stuff. I can't find a high heat primer. Auto store or paint store. So I'm at a stand still with my project. Thanks for all help. This board is great!
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Most common paints can handle the temperature of a water radiator--steam gets a bit "iffy".
    If the current paint/coating is in VERY good shape you can use latex paint, but oil-based coatings are HIGHLY preferred and absolutely required if you're going over bare iron. As with any paint, if there is a thick buildup of layers and cracking has occurred, you need to remove the old paint. Sandblasting, a soak in lye and pressure washing (zero-degree nozele) are all effective methods.
    If rust is showing through the paint, then latex was probably used and it must be removed and primed/painted with oil-based paint. Again, if the coating is in good shape--just dirty--do you best to clean. If you're pretty certain that the latex paint was used in the past then use latex--if you're fairly certain that it's only been painted with oil-based paint, then use oil. (When switching between oil/latex you can only switch once.)
