attaching aluminum transfer plates
Steve Minnich_1
Steve Minnich_1 Member Posts: 127
The only time I've used perimeter radiant heat is in multiple dwelling units such as apartment buildings where the heat loss is low or in a radiant cieling applications where I can jack up the water temps.
Your first step would be to have an accurate heat loss calculation done to determine your specific needs.
Extruded aluminum plates can be installed in many different ways and applications. See posts below. First things first.
Steve Minnich, Radiant Comfort Systems
  • dorothy
    dorothy Member Posts: 8
    WHAT IS THE BEST WAY TO INSTALL HEAT TRANSFER PLATES ?
    CAN HEAT TRANSFER PLATES BE PLACED AROUND THE PERIMETER ONLY? IF NOT, WHY ? IF YES, WHAT MUST BE TAKEN INTO ACCOUNT?
  • dorothy
    Using heat transfer plates around the perimeter of a building
    Does anyone have experience with installing aluminum heat
    transfer plates around the perimeter of a building only?
    If so, what needs to be taken in to account? How does this type of installation effect energy efficiency?
  • dorothy
  • dorothy
  • dorothy
  • dorothy
  • dorothy
