Roth vs warmboard
Glen
Glen Member Posts: 854
Has anyone compared Roth Vs Warmboard floor panels? And used them OTJ??
  • Mike Reavis_2
    Mike Reavis_2 Member Posts: 295
    I installed Roth board when we renovated the bedroom.
    I am pleased with the performance. It went in well. I probably would have left a little more space for expansion at certain points--but it is silent when it is up to temp. I used the Roth pipe--I have been told that the Weil-Mclain pipe will work in the board (3/8") But you would want to recheck this.
  • Terry Alsberg
    Terry Alsberg Member Posts: 6
    What do you mean by OTJ?
    If OTJ is an abbreviation for on top of joists, I do not believe that the Roth panel is a structural panel which can be directly attached to joists. If it is, it violates my patent. If OTJ means something else, I am dying to know what that is.
  • Robert O'Connor_6
    Robert O'Connor_6 Member Posts: 299
    Which
    is your panel? Did you design or manufacture it?
    Regards,
    Robert
    ME
  • Dave_14
    Dave_14 Member Posts: 17
    expansion issue
    Mike, you were mentioning that you had a small problem with expansion when you installed the panels. I am about to install the same panels and am wondering if you could enlighten me with what you encountered.
    Dave
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    Terry...
    I think it stands for On The Job, like OTJ training...
    At least thats MY interpretation. Could be something else though... Let see,
    ME
  • Dale Pickard
    Dale Pickard Member Posts: 231
    Styrofoam
    Terry,
    The Roth panel is an aluminum panel bonded to styrofoam. It wouldn't make much of a structural subfloor. ; - )
    Dale
  • Glen
    canadian supplier??
    Ca anyone offer info for a Canadian supplier - preferrable AB or BC?
  • Mike Reavis_2
    > Thanks
    > Dave
  • Mike Reavis_2
    > Thanks
    > Dave
  • Mike Reavis_2
    > Thanks
    > Dave
  • Mike Reavis_2
    the noise was minimal
    and probably would go away if you used plastic sheets, or something where the pipe is not in the panels, and has an opportunity to rub against wood (near the manifolds.) You might want to check about using silicone sealer in the tubing grooves. If you want a fax of my tubing layout for this room, send me a nuber by e-mail. They won't let me near the scanner yet--someday!
    Mike
  • Sean Leonard
    Sean Leonard Member Posts: 2
    Roth Panel
    Hi Glen.
    I am the manufacturer's rep for Roth Panels in Alberta. You can contact me with any questions at 780-452-8661.
    Cheers!
    Sean.
