wirsbo contact
rodr
Member Posts: 20
The gyp-crete installer wants to spray a bonding agent made by quikcrete to the floor prior to the install.He says that he normaly sprays over the wirsbo tube so I would like to know if any of you have a good contact at wirsbo to confirm that this adheasive is compatible with the tube.Thanks for the help.
Rod
Rod
Tim Doran
Wirsbo
(952) 997-5334
Tim.Doran@wirsbo.com
Your friend in the industry,
Alan R. Mercurio
Oil Tech Talk0 -
Thanks Alan
Give me a call. An MSDS sheet on the product would be helpful.
Tim D.0 -
Most gypers
use a water soluable latex based sealant.
It by gully better be OK, cause I've got over a half million feet of it installed exactly as you describe...
PEX is a lot tougher than most people give it credit for...
ME
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
