News from B&G
DanHolohan
Member, Moderator, Administrator Posts: 16,687
NEW BULLETIN HIGHLIGHTS ISOLATION FLOW CONTROL FLANGE
Morton Grove, IL. May 4, 2004 - A bulletin that illustrates how a new isolation flow control flange combines the features of a flow control valve, isolation valve, and companion flange in a single valve is now available from Bell & Gossett".
Bulletin A-118 describes how the Check-Trol' isolation flow control flange from Bell & Gossett delivers minimal pressure drop, allows the circulator to be removed without draining the system, and makes pump installation much easier.
The bulletin also provides operating data and instructions, including maximum working pressure, maximum operating temperature, materials of construction, and the dimensions and weights of the various models.
Bell & Gossett
Bell & Gossett, a unit of ITT Industries, is a leading manufacturer of centrifugal pumps, circulators, hydronic specialties, heat exchangers, and packaged systems for variable and constant speed pumping, heat transfer and pressure boosting. For more information contact Bell & Gossett: 8200 N. Austin Avenue, Morton Grove, IL 60053; phone 847/966-3700; fax 847/966-9052; or visit www.bellgossett.com.
Bell & Gossett
Retired and loving it.
I saw one of these when I was at B&G...SLICK!
Watch for some new balancing hardware coming out in the next couple of weeks. SWEET!
Tom Meyer
Senior Designer/Trainer
Precision Hydronics Corp
www.precisionhydronics.com
- 87.4K THE MAIN WALL
