source of bypass radiator valve?
Joe_30
Member Posts: 85
Does anyone know who makes a manual radiator valve to turn down the heat of that radiator AND divert the flow to a bypass pipe going around the rad,[ for use in a monoflo system.] I have to guess a little in installing salvaged radiators, and need a failsafe if I over- radiate a room in a series setup.
Or, would you just use a regular rad valve and then a small ball ? valve on the bypass.? Thanks, joe
If you have acess to the mains Apollo makes a real nice 3-port valve that would work nicely. Fitting 1 in above the floor may be difficult.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
