3 Phase Motors
Servicewiz_2
Servicewiz_2 Member Posts: 28
I am very interested in any information that can be obtained on the resistance reading (OHMS) on three Phase A/C motor windings.Any help is greatly appreciated!!!
Servicewiz
  • Dave_22
    Dave_22 Member Posts: 232
    Resistance
    It kind of hard to say an exact number. Typically low .5 to 2 ohms phase to phase. And you BETTER read infinite from phase to ground or extremely high if your using a megger.
  • Victor H Plank
    Victor H Plank Member Posts: 17
    > Servicewiz
    The readings L1-L2, L1-L3, L2-L3 should all be the same and above zero...also check the three legs to ground.
    Not really sure what you are looking for or why.
    Vic Plank
    Lancaster PA
  • John Starcher_4
    John Starcher_4 Member Posts: 794
    > can _BR_ > be obtained on the resistance
    > reading (OHMS) on _BR_ > three Phase A/C
    > motor windings.Any help is _BR_ > greatly
    > appreciated!!! _BR_ > Servicewiz
    > _BR_ _BR_
    > check the three legs to ground. Not really sure
    > Vic
    > Plank Lancaster PA
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    why do you want to know the ohms--test it static then test after operating and windings have expanded ----if you are trying to diagnos a motor going off on overload -there are a few more things to look at --contacts in line starter,wires going to it ,control panel ,wire connections,motor load ,phase inbalance----use the middle contact for the low leg --correct voltage within 10% of rating -etc...
