Burnham Install
Justin Gavin
Member Posts: 129
We installed a hydro air system with 2 zones.
The base of the plant was a Burnham Revolution.
In floor in the basement upstairs we will do some spot floor warming and the majority of the house is going to be heated with a variable speed air handler with 2 zones. This system replaced an existing furnace.
Going to heat the hot tub as well.
Don't mind the mixing valve. My rookie didn't pipe it right and will fix it when we do the infloor.
C ya
Justin
C ya
Justin
Tom must be .....
very HAPPY !! Nice and neat Justin !!
Murph'
Nice...I seee Heatboy's Diamond plate is getting very populaR
mAD dOG
Really nice Justin!
Very professional looking install.
Mark H
Doesn't...
...Justin work for Heatboy? Neat work!! With the price of steel moving up fast, is diamondplate a sure thing for 2004?
Nice accouterment
will have to go diamond plate onea these days
)) That is slickness:) seems to generate the workmanship into another realm. lets go diamond plate
diamond plate
what are advantages of diamond plate other than lookin' good? seems plywood would be much easier for mounting purposes. don't get me wrong , i think it makes for a gorgeous base but might add a few shekels to the project both labor and material0 -
Bob young ...It's a radiant thing
reflect on radiant:)
is there anything bad about reflection....:)0 -
Nice
Very nice Justin.
Looks like your happy with the propress.
Keep up the good work.
Scott
reflection
reflection is good. just wisht you would reflect on my inquiry so i too can become a radiant type dude.0 -
Diamond Plate..
Maybe we should change the code and require it. Makes a nice samich! Nice looking work...Robert O'Connor/NJ0 -
R O'C
Robert, you don't by chance happen to have a daughter in Green Twp.?? KB0 -
There are advantages
You actually attach the plate to plywood so you still have a base to work from.
Also when you paint plywood it always seems to smudge and you have to retouch things.
With the plate you just polish and go. Also when you are marking out boards you can use a dry erase marker to mark your piping layout to keep everything nice and neat.
From a sales standpoint when someone comes over and sees it just grabs there attention and peaks there interest. You have your name stamped on and when they are considering a house hopefully they will remember you or at least inquire.
Plus it just looks Kick Butt.
Thanks Heatboy
Justin
KB..
No, not to my knowlege. Where is Green Twp? Robert O'Connor/NJ0 -
Diamond plate
is a very nice look. It is a little tricky to drill, however, if a hole needs to be on the slope of one of those humps!
Heatboy takes DP to new levels, and is King Diamond. Keep up the great work Team Climatec
I did see DP used back at the first RPA show, in 95, by Hughes Hydro Panel Plus, Middlehope, NY. along with a nice skid mounted boiler/ indirect tank arrangement. They were years ahead of us.
Typical New Yorkers. Someone told me long ago wherever you go, or whatever you do, someone from New York has been there or done that before you
hot rod
