How do I Run a Hot Water Zone Off a Steam Boiler
madmun
Member Posts: 2
I want to add a baseboard zone to my basement. I understand how to do it for above the water line. My question is, Do I install it for below the water line the same way as for above the water line?
Condensate zone..
Yes....Robert O'Connor/NJ0 -
The best way is to
have a tankless coil. That becomes a complete zone on its own with the right approach.
Taking it off the condensate below the NOWL will have you eating pumps like mad - but is nonetheless do-able.
if you use a....
y-strainer and a bronze circulator you should not have a problem.....using a standard cast iron pump...maybe a year and a half life....kpc
I have done this several times with great success. Click on "Heating Q&A" at the left of your screen. Dan has this all figured out for you.
Dave in DenverThere was an error rendering this rich post.
dont even think about doing this, without...
using a high torque 3 peice bronze pump
a water cooled and lubricated pump needs, well, "water", you cant do that with slude, and the bronze body will keep the iron oxide sludge from sticking to it0 -
Are you a homeowner or GC?
It may look easy, but to do it right you need some hands-on experience. Mad Dog0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
