gyp-crete questions
rodr
Member Posts: 20
I am having gyp-crete installed and the installer normaly sprayes primer to the floor before the gyp-crete.I ask him if there is any problem with primer on the wirsbo and he sayed no.Also i have concernes with the sheetrock wicking up moisture from the gyp-crete. Do any of you have any experiance with gyp-crete and can give me some guidence.
thanks
Rod
thanks
Rod
Gyp-Crete
Normaly they use a latex primer on our jobs, I have talked to wirsbo and they said it is ok,I would find out what they are using and contact Wirsbo to make sure.
As for the moisture concern I do all the pours on our jobs before sheetrock and also fire up the system to get rid of the moisture so we don't drive the moisture into the walls.
I would open windows and use fans at least and don't fire up the system untill your sheetrock is sealed.
S Davis
Apex Radiant Heating0
