radiant floor quick trak problem & question?????
steve_6
Member Posts: 243
Just installed a radiant floor in a kitchen using Wirsbo's quick trak panels. The installation went pretty well but I noticed the return panels didn't seem to hold the tubing tightly. Used the silicone adhesive according to instructions but when I pressure tested the system a couple of the return loops popped up above the surface of the return panels. Do I need to worry about this, or id their something I can do to correct the problem. The tile setter is going to put wire lath down and then his layer of mud on top of it. Will this solve the problem or will this cause future problems. Thanks in advance!!! Steve
Quick Trac
Steve,
Just put more silicone in the groove and then take a piece of panel and screw it down until the silicone sets up.
Mike Norgan
