Wirsbo ProPanel-PGP
Paul Pollets
Member Posts: 3,656
At least for commisioning and ease of piping. The rest of the renovation was difficult in that the GC cut many of the original piping laterals to the ceiling radiant and radiator mains. It was a tuff call to trace out the mysteries. We used a ProPanel 311 for an indirect tank, radiators, original steel pipe radiant ceiling, concealed wall panels and 1000SF of new QuickTraK in the Kitchen and 2nd Fl.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Ooooh
dat's nice. I have a 201- coming for a job soon. Looking forward to it. WW
Pro-Panel
Nice work, Paul. I have yet to use a Pro-Panel but I have the same 311 panel sold for an upcoming project. I'll let you know how it goes.
What kind of boiler is that? :0
-DF
It's a willie..
...Looks like a CG-6?0 -
very nice
? does the panel come with the ball valves stubbed out on the bottom or can you remove the front lower brace for ease of soldering?Dave0 -
Earthquake strap?
Is that the purpose of the #30's wall strap? Nice boiler(G). Those ProPanels are sweeeeet! We just comished a retro-fit with several of them.
pro panel
Hi Paul does this panel have a btu rateing , I have seen them on the wirsbo disk . we are using Danfoss panels now , there made here in calgary and have worked great improve our jobs , mabe we'll catch up to you some day , like were in a comopatition eh , you consistantly do such nice work and that is the key , keep up the beutiful work
Nron0 -
Panel
Thanks,....the panel is similar to the Danfoss and made by them.
Panel choices
Next time I'll use the 3 way Belimo mixing valve instead of the injection pump. The panel is available with either option. It costs a little more, but I prefer 3 way to injection. The W/M boiler should have been replaced with a Viessmann, but the owner wanted to use it until it dies.
You East Coasters...
forget about West coast code requirements to strap all tanks...water tanks require 2 straps.
Ball valves
are the terminus at the bottom of the panel. It's very easy to solder up.
Nice to see the finished product
Paul,
Looks as everything went well after I left. It's amazing to see what you can do with an absolute mess that was their before. Look forward to working with you again.0 -
Hydronic Panel
Paul, nice to see a great job.
Since I left Danfoss and joined up with Wolseley Canada, we have continued to promote Pre-Fab Panels. Whether its Wirsbo Pro-Panels or Danfoss ZCP Panels, the Benchmark continues to be set with these two great companies. I'm interested in why you chose to install a panel over site assembled materials?0 -
Reasons
Hi Dave! This was a project that only a fool would want. The mechanical room was such a mess, the only hope was to panelize the near-boiler piping. There was also limited room to organize the various zoning. It saved at least 2-3 man days of labor.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
