WarmBoard noise?
Nron_2
Member Posts: 4
the elimination of air can be done with a spirovent it will remove the microbubles from the system , if you are worried about noise use a contstant flow throuth the loops and set up a injection system to keep expantion down to minamim ,keep asking questions till you get your answers .
Nron
Nron
Warmboard Noise
I am planning on using warmboard for my house. I am wondering if there have been any issues that any of you have seen regarding noise from thermal expansion of the tubing, or any tricks/methods you can pass on to ensure a quiet installation. The Warmboard folks seem adamant about having the manifolds 3 feet off of the floor to eliminate air. Does air in the system create alot of noise? I am planning on using a condensing boiler, with outdoor reset.
Thanks for your thoughts!0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
