Munchkin in a P/S loop...
Nick_11
Member Posts: 25
Are there any problems using one pump on the return side of Munchkin as part of a 12 ft. primary loop (see diagram below)?
All HTP Preferred diagrams I've seen show Munchkin with pump on return side in loop off a closely spaced Tee's on a return header.
Nick
Nick
Yes it wil work
The fact that the supply and return are isolated from each other will prevent gost flo.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
