Electric radiant................Our way..........hb
heatboy
heatboy Member Posts: 1,468
We started this up today. We used 1/2" tube, but 3/8", 5/16" or smaller could be used. The heat source is a Thermolec fully modulating electric boiler. We found this line from Dan's manufacturer's link (to the left). I've done electric boilers before, but this one is cool. Outdoor sensor and all.
The Wall and Nextel's Direct Connect is a great combination. I had a question about this boiler and called Scott Milne via 2 way and he checked here for the phone number I needed. Instant gratification with no guilty conscience. ;-}
hb
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=304&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Nice!!
    Great little project!! I like the approach. I've been wanting to try this model, and the local Viessmann rep has one on display. Electric rates are .03 cent/KW in some parts of WA, so electric boilers are common East of the Cascades.
  • Dave Palmer_3
    Dave Palmer_3 Member Posts: 388
    whats
    under the tube tarpaper? looks cool,Dave
  • Brian
    Brian Member Posts: 285
    Nice
    Very nice heatboy
    Do you just have the boiler set to floor temp?Also is that the expansion tank above the boiler?
    Brian
  • leo g_13
    leo g_13 Member Posts: 435
    kewl!
    > hb
    > _A
    > 304&Step=30"_To Learn More About This
    > "Find A Professional"_/A_
  • leo g_13
    kewl!
    HB, i've had mine sitting at the wholesalers for about a month now. the project just had the floors poured today. i was in contact with the chief engineer, and they are going to be offering a model, that will be able to do an indirect tank. call for heat to the tank will be prioritized. what setting are you using in your area? out here we will probably use number 6.
    leo g
  • Weezbo
    Weezbo Member Posts: 6,231
    way ta go!
    that is a homeowner with a art work in his basement!:)
  • heatboy
    We will start at #5.
    Leo,
    The load for this area, as you can imagine, is quite large. Reset of some sort was mandatory since water temps at design will be higher than I would like when it is 40°. Once the cold weather comes back, (hopefully, not unti this October!) we can set the ratio. Since the AUST will be quite low due to all of the glass, I'm not to concerned about surface temperatures of the floor. More concerned with keeping the floor loaded.
    hb
  • Dale
    Dale Member Posts: 1,317
    Beautiful!
    One question, the tube looks like aquapex. Is this boiler used just for the sunroom or is it domestic supply also?
  • heatboy
    It's hePEX.
    Thanks, Dale. I can do projects like this all day. Basically a day and a half and it's done and on to the next. I do plenty of those projects that take a year or more to complete and just drag on. I guess I get bored too quickly ;-}
    This is a heating only application. Anyone that knows me can tell you that I haven't/wouldn't/won't use any non-barrier tube for radiant of any kind. Ludicrous to do so, IMVHO.
    hb
  • Uni R
    Uni R Member Posts: 663
    Nice to see a Thermolec...
    Absolutely beautiful install. The Thermolec boilers intrigue me. If I ever had a super insulated house that I could heat with under 10KW, this is the way I would go even with electrical costs being higher. No flu, no CO potential, not even that heavy of a circuit requirement when under 40 amps. And if it were a 2 temp design, I'd use two of them. The only tricky part would be tapping into a neighbor's buried electrical feed. L
  • ScottMP
    ScottMP Member Posts: 5,882
    HB
    Glad to be of assistances.
    In my area I would need supplemental with a project like this, what is the load ?
    What do you intend to run the floor at ?
    Is that tar paper underneath, and if so are you concerned with of gassing ?
    I am going to contact the Guggenhiem about your work :)
    Scott
  • Weezbo
    just curious...
    what are the supply ,return,and room temps?4 degree margin?
  • heatboy
    Initial design criteria.
    Weezbo,
    The load at design temps (Philadelphia, 15°F) is 40 btu/sq. ft. 10° Delta t with a supply temp of 120°. The beauty of reset is the floor will never see those temps (or higher) until design. With this kind of water temperature demand, the floor would be very warm during moderate weather with a set point control. Outdoor reset was the reason I chose the Thermolec boiler. But after installing it, it will be my first choice when an electric boiler is needed.
    hb
  • Weezbo
    is 40 below zero today *~/:) and the wind is picking up....
    and its just past october...
  • Weezbo
    TIM look at THIS ELECTRIC RADIANT its good 4 yo mynd
    its about 15 outside and its just about may....
