VENT DAMPER SPINNING!?
adambuild
adambuild Member Posts: 422
Any ideas? Can an EFFIKAL RVGP6BK be repaired if the unit spins continuously when the boiler is not firing, or does it have to be replaced? I'm assuming that microswitch is stuck/broken. Thanks in advance, Adam
    Steamhead Member Posts: 18,205
    I'd replace it
    but first, check to see that it is wired correctly.
    Consulting
  • What brand of boiler
    is this one on?
    Glenn
  • Weezbo
    Weezbo Member Posts: 6,231
    WoW!
    That aint supposed tyo happen, is that the new Effical ul listed for oil fired boilers vent damper that just came on the market a few years back? Id open it and dissconnect the wires to it tell me if the furnace shuts down...I m here with you ...
  • Weezbo
    if its a gas model....
    then there may be some reason that it must open or close due to some safety feature how ever if it is for the oil burner then it is an energy saving devise and may be opened and the power dissconnected with out any further ado and with out an operational change in the boilers firing or burn. i belive it is supposed to close after post purge to eliminate drafting through the stack of latent heat...That is a designe feature to save quite a chunk of change during stand by...i go reasearch this right quick and BRB
  • Weezbo
    Hello again
  • Weezbo
    Hello again
    If it is gas there is supposed to be a" hold open" to aid in trouble shooting.... it prefoms basically the same function as their oil flue damper... mostly set up around economy..and justa bout zilch to do with burn operation or function...the gas model that runs off the burn cycle is motorized as it were by voltage supplied during burn so i gotta figure that isnt the type you have.unless you have a standing piolit and some thermocuple in That equasion.
  • Weezbo
    i'm inclined to go with steamheds advise.....
