converting steam heat to base board
dave_33
dave_33 Member Posts: 1
How would you go about staring a project like this ? would it be a expensive project doing 7 room ? where can i find info please help.
    Steamhead Member Posts: 17,508
    Baseboard on steam
    generally doesn't work well unless it's connected two-pipe. If you have a one-pipe system you will need to run return lines to the baseboards. This can be costly.
    If you're having trouble with the system and think switching to baseboard will help, think again. Switching may actually make things worse if not done right.
    Tell us more about the project. Why did you want to use baseboard? What kind of steam system is it?
    Consulting
