buderus
shawn laverty
shawn laverty Member Posts: 42
Why are buderus boilers so great are they good for just all high temp zones and no radiant also would you use a logamatic control for just high temp zones if yes why I understand there great for radiant.Any answers would help
  • Nron_9
    Nron_9 Member Posts: 237
    Buderus
    They are verry well made boilers and are well insolated , they can work for radiant floors and for high temp , the come in 1 or 2 stage and you can use the logomatic control or tekmar controls to operate the boiler , always reocend out door reset for heating systems , these boilers will last a life time if taqken care of Nron
  • rod robbins
    rod robbins Member Posts: 50
    I have a buderus running both high temp and radiant floor plus domestic hot water.I have wirsbo 311 out door reset controls.Its been a very sweet boiler.Nice and quiet and its my understanding this boiler is able to handle lower return water temps then most non-condensing boilers.It also makes a very clean looking mechanical room when combined wih there tank.
    Rod
