solor panels
rod robbins
Member Posts: 50
I have around 10 solor panels made by ppg that came off a job.Does anyone have any sugestions as to were the best place is to sell them.They are around 2x6 ft.I hooked one up to a hot tub but the water came out to hot to be safe so I stoped using it.
Rod
Rod
redirect
put them in the paper of on line some one will want them if theprice is right , but since you have them why not use them youself , hook them up to the domestic for the house and add a buffer tank if there is room , solar can work great as a suplamental heat source NRon0 -
hay rod how close are you to maine i could use them to heat my pool0 -
I live is seattle Wa.0 -
If i wanted to kook them up to my radiant is there a standard way to integrate.The system i got these from was very complicated and they had a 5000 gallon holding tank and pulled the heat from the water with a warm air heat exchanger.My system is a standard buderus with infloor.I have domestic priority and a high temp zone for future expansion.I would need to use glycol in the panels with a heat exchanger but i am not sure how i would control the system.You just got me thinking about trying to use them.It would be a savings for sure.
Rod0 -
contact eric legacy at buderus0 -
panels for rick
Hey Rick, Im in NH I got 10 panels for sale maybe.0 -
Ya mean...
like THIS??
ME
Hey Mark, simple but effective.
e.l.0
- 167 Indoor-Air Quality
