PEX repairs
marco_4
Member Posts: 7
I need to repair/replace some leaking low temp baseboard that's connected w/ pex tubing. The pex is 5/16 i.d. and 7/16o.d. The copper tubing on the baseboard is 1/2 inch o.d.
I'm having trouble locating fittings that will make this happen. Any suggestions?
Wirsbo
5/16 fittings to 1/2" copper.0 -
and another fitting
it is a transition fitting from copper to wirsbo. that you thread the fitting on the picture into. i hope it helps.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
