Painting and Humidty
mattman_2
Member Posts: 2
Anybody have any recommendations for humidity levels in a spray booth application? We have a guy that spray paints plastic parts and gets little impurities that stick to the plastic in winter, thus ruining the finish. He believes it is static that is the culprit.
Low humidity is usually the LAST complaint in a spray booth!
But, some plastics can hold a really high static charge and the painters' theory may well have real merit.
Any way to neutralize the static charge in the plastic parts? I'm kind of seeing a big soft copper brush attached to a good ground...0 -
Static & Plastic
Have been thinking of this since posted...
http://www.merkurencyclopedia.com/Exterior/painting_interior.html
Note that they recommend TWO washes with an anti-static degreaser prior to painting (plastic car parts).
Other thing I found where static was mentioned when painting was with snowboards. Didn't copy the link but it should be easy to find...unless you're a snowboarder I guess...
Anyhow, extremely soft copper brushes are often used in snowboard prep.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
