Buderus g215 - Venting question
John_41
Member Posts: 1
Just had 215-3 oil boiler installed w/F5 Riello burner. Installer stated that a barometric damper is not required for the vent, since it is 'postive pressure'. A 7" vent taps into a standard 10x10 clay lined masonry chimney. The chimney is about 20' tall(2 story house, no basement). The old WM had a baro. Anyone have thoughts on this?
I have seen some application where the damper was not needed.But here code require it if you need it or not.
jmho.0 -
Well
For openers I believe there is a slight positive pressure over the fire but that the flue will be negative. A barometric doesn't add draft it just controls it.
"high pressure goes to low pressure"
Local codes and the I/O dictate.
However it may be that in a 20' chimney draft is marginal.
I would put one in regardless . It willl stay closed if it's not needed. And on those cold winter days when it may be needed you'll get good starts from that Riello. Riello's really like a zero to slight pressure in the fire box and a draft regulator will give it to you every time.
Robert
ME0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
