Two B vents (how close/)
Phil_8
Member Posts: 42
Adding a separate system. Are there any restrictions on how close the two B vents can be on the roof top?
NY code
I don't see anything about how close they could be after the proper hight is reached in the Fuel Gas code of NY. You may want to check with the manufactures installation instructions....Or ask the local inspector .0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
