controls
rob_23
Member Posts: 8
I want to add a zone to a previous system with circulators and Honeywell 845. Is it possible with 2 845's in system? If you have a wire diagram please share.
possible.
it is possible to add a second 845 control and circulator into a system. The wiring diagram is generally included in the package when you purchase the control. I would recommend caution if you haven't done much work with wiring, get's expensive when you let the smoke out.
You can destroy the existing system on top of the new control if you wire it wrong...0 -
Adding a Zone
get in topuch with me by e-mail and I will get you any diagram you need. E-mail is gastc@cox.net.0 -
You can also go here
http://hbctechlit.honeywell.com/
Just type in the numbers of the products you're working with.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
