stacking capacators
Alan_6
Member Posts: 87
Is stcking capacitors good or bad, on a compressor. For example: A compressor calls for a 75 mfd X 440 Vac capacitor. A 35 mfd x 440 vac + 40 mfd x 440 vac, wired in parallel. If one of these capacitors burnt out, the compressor may run, cause a severe burnout, instead of tripping a breaker? Any thoughts?
I do it....
...only as a temporary fix if the proper size capacitor is not available. Wouldn't recommend it as a permanent repair.
Starch0 -
I dont see a problem,if one was to burn out it will most likely not start at all,and even if it did try the overload
would properly take it out.
I would make sure its 440 the 370 volt dont seem to hold up
as wells as the 440,only and certain neighborhoods.
Hmmm..I wonder why.
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
