Transfer Plates
BOB_22
Member Posts: 16
I,m installing Wirsbo 1/2" pex with plates. The place where I bought the pex from only sells the plates in packs of fifty(I only need ten or twelve). I found on line a place that sells the (c) plates separately. My question is, will the Wirsbo pex fit in these plates? The advertisement said, will fit Rau pex(I'm sure that spelling is incorrect). Any info would be helpful. Thanks
od
Anything 5/8in outside diameter will fit in plates designed for 1/2in pex.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
