Hydronic contractor in Kansas City area
Dennis88
Member Posts: 2
I,m searching for a good hydronic contractor in the Kansas City area. Only contractor found, wants to remove boiler and install a hvac system. Would like to have hot water heat and a air controller for the ac. This contractor says that a new boiler will cause the valves to leak on the radiators and that contaminates in the pipes will plug the new boiler. This house has a ng converted boiler about 90 years old and is a gravity fed hot water system.
Don't listen to him
If you want the cheap way out and a dry drafty house let him put a furnace in. Why not check the find a contrator page up above to find a REAL Hydronic pro in your area. If the system works, just replace the boiler. Don't buy that contaminates bull. I would never recomend a hot air system in an older home.0 -
KC area contractor
There are numerous skilled contractors in the KC area. Contact Larry Lange @ Heating and Cooling Distributors 913 262 5848. He's a great hydronic wholesaler and I'm sure he can provide several quality contactor contacts.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
