panel rad engine room (leo g)
leo g_13
Member Posts: 435
just finished this installation. each of the 10 panel rads have their own supply and return, and are balanced with Dahl balancincing valves. they will also be equipped with TRV's and the system will run off of the tekmar outdoor reset. the HO has been the driving force behind this project, and has been one of the best that we have had the pleasure to deal with!
if possible, we try to get the panel installed before the drywall, so that all of the wiring possible, can be "hidden".
enjoy!
leo g
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=286&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
enjoy!
leo g
Nice looking work, congratulations. Tim
Leo!
That is real pretty.Nice work.One thing.......I always like to isolate the expansion tank also.And as you I always installed a ball valve.It is a handle that someone can possibly close or forget to open after service.Likely,no but possible.I use a check valve now.1/2"M NPT x 1/2"FM NPT.Watts make them ,I dont know the part # off the top of my head.It is discreet in appearance and has a small spring.When replacing the tank the check snaps closed.I buy a dozen @ a time.What type of finish on the panel?Very nice.I love the panels with TRV's...set em and forget em!.
cheese0 -
Very nice, Leo
That wiring method looks great! You are wise to valve the PAB like that, also.
hot rod
didnt waste a dime on that one:)
clean.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
