History of Plumbing in photos (s milne)
ScottMP
ScottMP Member Posts: 5,882
and gather around.
You old timers just jump in and help with the explanations.
We are renovating a house a good customer just bought and this is to be the boys bath. We noticed some lead pipe so, up came the floor.
There right in front of us is the best example I have seen in years of what the dead plumbers did.
Not only lead drains ( we see those often ) but lead water pipes still in use !!
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • ScottMP
    For those who dont know.
    lead piping was how plumbing was done before cast iron. Lead was used for water piping also.
    The Plumber would take a asbestos cloth and fold it. While holding it in his hand, he would take a ladle of Hot Molten lead and pour it into his hand. While he poured the molten lead he would wipe the pipe and make a joint.
    Look at the water pipes and how they are connected.
    How far we've come. Lead and asbestos.
    " The Plumber protects the Health of the Nation "
  • ScottMP
    Heres a few more
    Years ago when I was cleaning out my old boss's shop we found a lead drum trap "Still" in the box, brand new.
    It dos'nt end here kids.
    The old towns water supplies had very little preasure. So a Cistern Tank was built in the attic. This was an open tank that had a ballcock similer to a toilet. This allowed the water to flow in. The water piping was then piped 'down" to the fixtures. It gave the lower fixtures like the kitchen sink Great preasure.
    These tanks where lined with copper and sometimes zinc, some even lead !
  • Al Letellier
    Al Letellier Member Posts: 781
    > The
    > Look at the
    > How
    > " The
    > _A
    > 237&Step=30"_To Learn More About This
    > "Find A Professional"_/A_
  • ScottMP
    Sorry
    We took out the wall hung tank for the bowl before I took pictures. Here is the feed that came out high up on the wall to feed the tank.
    This dos'nt show the "Local vent" that vented the bowl only to remove " Ye Ole Odour " . This was piped up to the chimney and was attached to the plumbing venting.
  • Al Letellier
    lead piping
    Thanks for the memories, Scott. Poured my first lead and oakum joint when I was 5 and wiped my first joint at 8. My great-granddad was a roofer by trade and fabricated a lot of fittings for the plumbers back in the 90's (1890's that is) before he became a plumber himself. Then granddad, dad, me and 26 others in the family tree over 4 generations....love that photo of the tub trap with the side cleanout plug...that is a rare one indeed...worthy of being saved for posperity in a museum or collection somewhere. Have a lot of the old pump up torches they used to use...like to see a young apprentice today fire on of those up and solder with it!!!!
  • ScottMP
    Thanks for speaking up Al
    I tried to photo some of the old torches but ran out of battries.
    Tell us more about how the joint was made ...
  • JB_2
    JB_2 Member Posts: 68
    old days
    got to love these old homes ! check out the wiring.still working?
  • Love seeing that old stuff
    Thanks Scott for posting the pics . We never see anything older than the 1940s .
  • Darin Cook_2
    Darin Cook_2 Member Posts: 205
    Very Cool!!!
    Scott, there is a lot of this old plumbing still in operation in the Albany, NY area. It used to crack me up when they started making us use 95/5 but the service coming in was pure lead. I could never get any of the old timers to wipe a lead joint for me. That is another lost art. When you have to tie on to lead pipe with a ford coupling it is always a challenge to get the right size, and you might have to do a little shaving with the jackknife to make it fit. You could always count on a newbie to run the gunsnake through the sidewall of a lead drain in a ceiling, then scratch his head at what the dead men had left him. Thanks for the cool pics!!
  • Mike Kraft_2
    Mike Kraft_2 Member Posts: 398
    Scott unearths.......................
    heavy metal.Turn it into gold:)A new twist on alchemey...........plumbing remodel.......turning the lead into greenbacks:)Nice find.
    cheese
  • sootmonkey
    sootmonkey Member Posts: 158
    Plumbers
    Nothing makes me as happy as flushing something down, and never seeing it again. You don't know the feeling, until you have a frozen septic. A cold one on me for the plumbers.
  • jackchips_2
    jackchips_2 Member Posts: 1,337
    Great stuff
    Scott, thanks for posting.
    I took the journeyman exam right around the time they stopped requiring a wiped joint-only a soldered fitting.
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,957
    cistern gizmo? etc.
    Hello: I see a gizmo with a wire attached to it, behind the fill valve. It looks like one would pull the wire from below and expect some result. Any idea what it was for? Maybe a way to raise the float when water overflows and drips through the ceiling? By the bye, the cistern is still common in British plumbing, from what I've seen... Do you think some of that old lead drain line would be quieter in use than ABS?... Those are some really nice wiped joints! I've got a book on just how to do it if anyone wants to do irreparable harm to their hands. Thanks for sharing.
  • Hey Scott, I've got another one for you.
    The toilet tank needs parts, and the seat is tired....
    Can you save it, or do you think it's time to remodel?
    Noel
  • Jim Bennett
    Jim Bennett Member Posts: 607
    Wow! That's what I call Art! Been doing plumbing going on 25 years, occasionaly pull out some lead drainage, but I have never seen lead water lines!! Cool pics!
    Jim
  • bob young
    bob young Member Posts: 2,177
    LEAD WORK
    GREAT PHOTO'S OF TRUE LEAD WORK.SOME OF IT WAS TRULY WORKS OF ART. ESPECIALLY THE VENTING FRAMES THAT WERE PREFABED ON THE KITCHEN FLOOR!! EXPOSED WATER RISERS HAD ORNAMENTAL STRAPS SOLDERED TO THE PIPING.DID PLENTY OF WIPING IN THE SIXTIES ,IT WAS INTERESTING BUT DIFFICULT. TAKING THE N.Y.C. TEST MAY HAVE BEEN THE HARDEST DAY OF MY LIFE .FOUR SOLID HOURS OF WIPING AND FITTING AND YOU ACTUALLY NEEDED EIGHT HOURS. ONE SLIP UP AND INSTANT FAILURE. KEPT THE RIFT -RAFF FROM GETTING A LICENSE. REAL CRAFTSMENSHIP AND LOVE TO LOOK AT IT BUT GLAD ITS OVER.
  • ScottMP
    Bob
    I am sure if it shows in any of the photos but, there are brackets that attach the lead risers to the wall. I don't think they are ornamental.
    I took the two "young" guys on the job and made them stop and look at this work. I told them as much as I could about the old work. I think it does them good to see what came before us.
    Scott
  • ScottMP
    Yes it is
    In the photo of the stack you can see a group of wires together. I believe these are for the alerting system that told the maid what room was calling her. There would be a box with little arrows and when a button was pressed in the room the arrow jumped up in the box.
    Anyone know the true name for this ?
    Scott
  • Nick W
    Nick W Member Posts: 200
    Latin
    The latin word for lead is "plumbum". The latin word for plumber, which escapes me now, translates to "leadworker". I always thought that was interesting.
    Look at this photo too see how a new "plumber" repaired an installation like my Dad might have typically done. Notice the ill-fitted Fernco coupling and PVC floor flange connecting that lead bend.
    And yes, that's lead water pipe encased in concrete (ash?) between the 5th and 6th floors of a Manhattan residential building.
  • ScottMP
    Looked this up
    On a latin to English website and this was the best I got..
    plumbum -i n. [lead; a bullet; a leaden pipe]; 'plumbum album' , [tin].
    I was told that Plum was lead and Bum was a worker, a worker of lead. I had a hard time finding a website that could confirm that.
    Its appears that Plumbum or Plumber was a lead pipe !
    Scott
  • jerrygb46_5
    jerrygb46_5 Member Posts: 5
    wires?
    I do believe that type of wireing was called "knob and tube" as far as the box i think it was called a "Anuncator" or something like that ??
  • Kal Row
    Kal Row Member Posts: 1,520
    you guys are so geelfull at the find
    just remember that all the Tsars that were carried by their pregnant mother in the Kremlin with the lead pipes - were mentally ill, Ivan the treble is a shining example of that, Peter the Grate’s mother on the other hand wasn't even allowed in - this stuff is real real dangerous
  • Kal Row
    look how i spelled
    Peter the "Grate’s" (great's) - there must have lead in my water too ;-)
  • Art Pittaway
    Art Pittaway Member Posts: 230
    Thanks Mr. Milne..!
    I hope it's OK, I've taken copies of the photo's onto Power Point. I teach a class called Residential Mechanical Systems at the local Comm. College to introduce students looking for a spot in the trades to how Electric, Plumbing and HVAC systems work and work together. And I have wanted some shots of Lead joints to show. I tell them you have to know where the stuff came from, in order to take it into the future. Went through a mansion in LaSalle/Peru Illinois, built by the Carus Chemical Co. family. Lead pipe and lead lined cistern in the tower. Servant used a hand pump in the basement to pump the tank full. Last two living relatives still lived in the mansion (mid 90's)each had a floor to themselves and didn't like or talk to each other. Contractor I was with said, "the whole family was nuts". Thanks again for the great shots. Art
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    They are called \"Annunciators\"...
    There is one in the crew quarters of the railroad car. A client pushes a button in their stateroom or the lounge or dining room, a bell rings, and a location pops up mechanically on the box. The steward then goes to the location indicated to take care of whatever they want. Most first-class railroad cars had them; office cars, Pullman sleepers and Parlor Cars. Lots of old mansions did, too.
  • Jimmy Gillies
    Jimmy Gillies Member Posts: 250
    Lead wiped joints.
    As a very young man starting my 'time' as an apprentice in 1974. You were still expected to be able to 'wipe' a joint in lead pipe with a mole skin wiping cloth. flux & a bar of solder. After mastering the craft of wiping a 'ball' joint on the work bench, you next had to do it UNDER the bench - because it was always in the most cramp locations most of our work was done.
    We were not installing lead pipe but with many old houses, you needed to join onto it.
    Thanks Scott for all the great pictures.
    Regards.
    Jimmy Gillies Scotland.
  • LEAD PIPE
    LEAD PIPE Member Posts: 199
    LEAD PIPE
    I will not stand for all this lead pipe bashing.
  • ScottMP
    Kal,
    We are quite aware of how dangerous lead is. Thast why I put the quote about the "protecting the health of the nation ".
    Those who do not know history are doomed to repeat it !
    Its good to see where we came from and it gives us a sense of who we are.
    I'm glad everyone enjoys this as much as I did. Kinda of a Wallie museum.
    Scott
  • Mad Dog
    Mad Dog Member Posts: 2,595
    That's how I earned my master plumber's license
    wiped lots of lead joints. Just 6 years ago. AAA lead for water services - just for practice. Wiping lead and being competant in screw pipe sets apart the real plumbers from today's "plastic plumbers." Lead and asbestos are great materials that HAVE protected the health of MANY nations and the greatest civilizations, mesopotamia, Greece and Roman. There is a great deal of hype about the dangers of both - just don't ingest either and you'll live a long life. Mad Dog
  • Mad Dog
    Next time you in Long Island......I'll put a joint up for ya pal
    You'll love it. Mad Dog
  • Constantin
    Constantin Member Posts: 3,796
    Found some!
    I just found some lead pipe in the house... yay! I'm trying to photograph everything before it is ripped out... knob and tube insulation, cast iron boxes for the wiring, gas lighting (!!!) supply converted to electricity, etc. We have a veritable archeologist dig here as far as infrastructure is concerned.
    And... demo guys work fast!
  • Mike Reavis_2
    Mike Reavis_2 Member Posts: 295
    DC lead water service--everyone is going into restaurants
    and asking for "unleaded" water. There are thousands of these all over the District, and they are all over the news. Mike
