Need a source for
Mark J Strawcutter
Member Posts: 625
I need a source for stainless steel crimp-on disconnect terminals. 0.25in, preferrably both straight and flag.
Mark
Mark
You might try Sta-Kon terminals. They are made by a company called Thomas&Betts. I know they make terminals plated with gold, silver, and nickel. They might make something that would suit your needs. The website is www.tnb.com . Hope this helps, Good Luck!0 -
What's
What's your application? Corrosion problems? You might want to look for something other than stainless due to the fact it is not as conductive as typical connector materials. Something in silver or gold plate will be your best bet.0 -
Yes, corrosion concern
Primary application is for A/C condensor connecting primary power to contactor. I seem to remember someone (not here) recommending stainless. Can't remember who it was :-( only that they ran about $3 each (ouch!) but saved him problems down the line.
T&B Sta-Kon is what my supplier handles, but they don't make stainless.
Thanks for the suggestion, I'll check into silver or gold plating.
Mark0 -
Another trick is to
cover the connections with shrink tubing. Goes on easy with a heat gun and comes off with a knife.0 -
i am suprised!
many of you live near the oceans ,the connectors used in boating and marine electrical would seem the best bang for the buck!0 -
die electric grease
Have you tryed a die electrive grease at your electrical connection have found it very usefully in corrisive eviorments help to cut down in corrisive situtions good luck peaceR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 987 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
