rad. floor heating
freddie g
Member Posts: 4
woundering if i can add a in the slab rad.heating zone to exsisting base board boiler and where to find info on tube spaceing and installiotn tips
im adding a large extention to home would like to put tubes in slab
You can if?
> im adding a
> tubes in slab
You can if?
> im adding a
> tubes in slab
You can if?
Your exisiting boiler can handle the added btu load. Need a heat loss of the structure first. As far as installation tips, hire a contractor that's the best tip I can give you. Someone that is a trained and experienced radiant installer.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
