repair cast ireon steam radiator
mike furst
Member Posts: 1
I would like to find someone to repair my cast iron steam radiator; 10 sections, leaks at section break on bottom between section 1 & 2. approx size of unit is 22inches high, 18inches wide.
I would also consider purchase of replacement, depending on price. Can be slightly larger.
I am in Plainview, long Island and Southold, Long Island, NY.
Thanks 631 734 7257 516 938 8829
Mike,
Repair of this radiator may be possible depending on where the leak is and the construction. Read "An Old Radiator Q&A" in the "Hot Tech Tips" area.
http://www.heatinghelp.com/newsletter.cfm?Id=20
I have successfully done this once (first try), removing a leaking section and reassembling an old radiator. Then try the "Find a Professional" link for someone in your area willing to attempt this.
Good Luck,
Jim
http://www.heatinghelp.com/newsletter.cfm?Id=20There was an error rendering this rich post.
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
