POWER VENT IS IN
Dave Merklein
Member Posts: 61
The power vent is installed and appears to be working but working loudly any one have any good sound deadening suggestions?????
power venter
how about a picture lookig straigt up from the floor showing how the flue pipes attach to power venter
Could you
please post a pic of the spill switch on the water heater?
It doesn't look right in the pic, but that could just be the angle.
Mark H
Never
had any luck trying to make them less noisy; that's why I don't use them anymore. Even though you tell everyone that they are loud, either the neighbor or the homeowner gets upset.
Is it OK to reduce the flue pipe like that?
the flue size being reduced is the whole reason for the power venter. here are more pics0 -
one more pic0 -
The spill switch looks like a manual reset cap. tube-looks fine. Have you tried resilient hangers? Might help a little. Good Luck.0 -
Chimney?
Are you venting into a chimney or just through a wall?0 -
why
the tape on flue pipe,isnt that negative pressure inside pipe.0 -
In to a chimney0 -
not the right unit
A power venter creates positive pressure. A chimney is a negative pressure device. You are pressurizing a negative pressure device. What you need to use is a "draft inducer". The draft inducer provides an assist for "lazy" draft but depends on the natural boyancey of the flue gases to maintain a negative pressure in the vent. by pressurizing the chimney you can create a potential hazard as the flue gases (will, can, may) escape the chimney into the living space0 -
there is a roof power venter ....
venting is an important subject..what you have there may be working. i belive it is for a wall penetration .i think it is like a hv1 .i know that i use them to shoot out a wall into open atmosphere. i wasnt aware the useage you've found was an option....it has a pre purge to insure(establish) flow .How long has it been functioning this way?0 -
I have had the unit 3 days. this was set up with the blessing of an engineer at weil mclain.0 -
any one have experience with the Tjernlund auto-draft power venter??0 -
powerventer or inducer?
Is this a power venter or an inducer? You may wanna run it by the guys at tjernlund as well.0 -
Tjerlund
This is a positive pressure fan and any pipe on the discharge side must be air tight. Not acceptable in normal chimney. Must have post-purge of 3-5minutes or will have condensation problems. Could be to much exhaust for drafthood appliances. Spillage will occur at bottom of appliances not top. The inducer can pull to much room air and not let all the flue gases out. Hope you have a combustion analyzer and know how to diagnose this problem0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
