Steam Boilers
Ray_8
Member Posts: 3
I recently installed a Bryant steam boiler that I piped the same as the old system. I had not seen the old system before. It has a tank above the boiler that is piped with return lines. Needless to say I am getting very bad water hammer and I know I need to repipe the boiler. I want to make sure I do it right this time . The radiators do not have traps at the outlets. The two steam mains are 2", returns are 3/4" and go to 1" pipes at the tank assembly. Both main supplies dead end. They are not looped together. Boiler currently is not piped with Hartford loop. I am not sure that this is my only problem. I have a copy of your book "The Lost Art of Steam Heating" if you can reference areas of the book. I also have pictures of before installation and tank set up if that will help.
Please contact me as soon as possible at this email address.
Thanks,
Ray
Thanks,
Ray
Ray, are you a tinkerer, homeowner , or contractor?
If you read Lost Art and followed it, you would be in good shape. Fill me in??????????????? Mad Dog
Mad Dog,
I am a small contractor in Pitt. area. This boiler went when the weather was cold. I gave a proposal and customer needed work done ASAP. I did not research the tank in the ceiling and piped boiler as close as possible to old system.
This being my first Steam install I am learning a lot of problems can arise without doing my homework. Any help will be much apprecited. Steam is not common in my customer base. I have serviced a few, but hate to turn down a customer.
Ray
THAT could possibly be Mr. Murphy's area. [Pittsburgh ] He is the expert there.0 -
How can I contact Mr Murphy. Is he a contractor or a service rep.
Ray0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
