Hercules Flip Stick?
Nick W
Member Posts: 200
Has anyone used this product in a residential gas boiler? What does it do?
http://www.herchem.com/Products/FSTICK.html
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=290&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
MSDS says...
it contains Cupric Chloride. I'd guess the chlorine attacks the carbon and creosote deposits (in preference to the metal in the boiler and flue), and copper was probably the most convienent metal to use to make the chloride salt. Not sure I'd use it in anything but a wood (or maybe coal) fired application though -- why do you ask?0 -
Since it is aimed at soot
why would a typical gas boiler require one? A gas boiler producing free carbon (soot) needs a lot more than a soot stick!
These are typically used in oil boilers with passages that are so dificult to completely clean - the service tech may throw one or two into the combustion chamber to get as much of what a good brushing and vacuuming may have left behind. Under no circumstance are they a substitute for a brush out and vacuum (or as some do - a water rinse/cleaning)!
The action is purely chemical. The "salts" react chemically and strip/burn free carbon from the fireside of an oil boiler HX (or scorched air) and wood & coal burning equipment.
The rare times we use them, they seem to simply turn the black soot to white and perhaps help a little.
- 129 Chimneys & Flues
- 122 Geothermal
