Carbonized Gas Boilers, Why does it happens?
Herbie
Member Posts: 3
As this past season has come and it is almost at an end, I have found so many residential gas boilers carbonized. I would like to know a little more about it. What causes it to carbonize? I work in New York City and the surrounding areas.I would appreciate any input (Besides the regular faulty gas valves issue...) that anyone in our field or related field could tell me. It seems to be quite a mystery and it seemed to be excessive. Thanks in advance for any sugestions and/or answers!!
Why?
Gas apliances usually soot up because of three things. 1). Incorrect incoming gas pressure. 2). Blocked or obstructed flue., or 3). Lack of combustion air...Robert O'Connor/NJ0 -
And if they soot up
they are probably making Carbon Monoxide as well. Use your digital combustion analyzer to verify this.
If you don't have an analyzer, GET ONE! Cause if you don't test, you're just guessing.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
You forgot one Bob...
Contaminated combustion air. Dust in suspension, like lint, sheetrock dust, corn pollen, dirt etc...
If you don't test, you won't know.
If you don't know, someone could die.
Test.
ME0 -
The # 1 cause is failure
to service the equipment at least once a year. The mis-conception that gas equipment does not need an annual tune up.
The #2 cause is service personnel who do not know what they are doing.0 -
Don't forget!!!!!
Enough air getting to the appliance to burn properly!0 -
All too common
This has been a problem for years just like rust and yet all I hear is that is why they need servicing every year. I agree we need to service every year but shouldn't we fix the problems? Venting issues are the main cause of both. Unfortunately you can still have even more dangerous conditions and neither rust or carbonization are present. A combustion analysis is very definitive if these problems exist if one knows how to interpret the information0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
