oddball radiant parts?
Bob Bona_4
Bob Bona_4 Member Posts: 2,080
Hi fella's..
I came across a "no-name" radiant system that has leaky manifolds/compression fittings. Looks sorta like Burnham hangers, extruded brass manifolds joined together with what I imagine o-rings. 10 loops. 9 of the loops go to panel radiant baseboard (high temp) the last one goes to a zone of floor heat. No mixing..ouch!
Each of the loops have a motorized actuator that has the words "behr" on them. All 10 of the actuators are controlled by a cute little zone panel "ABS410". Looks like a Honeywell MABS panel, but again, no name..
The PEX is German, and stamped with things like "systemrohr" (I was wondering if HR made it :)), and ""sauerstoffdicht" Looks in between 1/2" and 3/8".
The panels are 5" high, 1" thick. The stats are Eberle.
Anyone know what the heck this system is? My local suppliers drew a blank too. If the Pex is compatable with Wirsbo, my mission is clear-replace with Wirsbo manifolds. TIA!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=167&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
