Angle Pattern Steam Rad Valve
Dave Heath_2
Dave Heath_2 Member Posts: 52
I am trying to locate a product that was manufactured by Spirax Sarco. It is a 1" FIP X 1" Male Union Series 740A Radiator Supply Valve. There are two valves that I am looking for. The first is called Model RH - RH Angle pattern. The second valve is called Model LH - LH Angle pattern. Spirax Sarco stopped producing this product many years ago, however I am sure my FELLOW STEAM WALLIES can point me to supplier or to another manufacturer that makes something equal.
Thanks,
Dave H.
  • gerry gill
    gerry gill Member Posts: 3,083
    is there some feature
    that makes this valve different from a regular valve.?
    gwgillplumbingandheating.com
  • Dave Heath_2
    Rad valve description
    The rad valve looks like a straight pattern, but instead of exiting straight thru the valve it turns left or right(90 degree side outlet). That is why it is designated RH OR LH. I hope this helps.
    Dave Heath
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,687
    Hoffman
    used to make those, but no more. Not sure if anyone does, Dave.
    Retired and loving it.
  • Jason
    Jason Member Posts: 17
    i need those too
    Somebody used the 90 degree (vertical to horizontal) valves laying on their side to make a horizontal right angle turn in several places in my house. I had problems with water leaking from the valve but new packing has solved it for now. When I called my oil service company to have a look, the steam guy they sent over said this installation is common. But I'd like to do it right with the RH and LH valves too.
  • paul lessard_3
    paul lessard_3 Member Posts: 186
    A friend just gave me one of those
    1 1/4, never been used..neat stuff
  • Dave Heath_2
    That's the one
    > _A
    > HREF="http://www.heatinghelp.com/getListed.cfm?id=
    > 302&Step=30"_To Learn More About This
    > "Find A Professional"_/A_
  • Dave Heath_2
    That's the one
    Thanks, Paul
    That is exactly what I am looking for, except in 1"
    Do you know where I can find some of these?
  • Dave Heath_2
    That's the one
    Thanks, Paul
