relay switches vs multi zone control panels
Jim_44
Jim_44 Member Posts: 23
What would be your preferance when it comes to using relay switches on a 3 or 4 zone residential hydronic system using circulators. Do you prefer individual relays for each tstat or the multi zone relay panel such as the one made by ARGO. Please let me know the pros and cons using either one.
Thank you
JIM
  • Joe Mattiello
    Joe Mattiello Member Posts: 740
    Joe Mattiello
    Technical Service Technician
    Joe Mattiello
    Taco Comfort Solutions
  • Joe Mattiello
    Taco, SR504
    Good Afternoon
    Taco, offers a multi zone switching relay, with priority feature, and diagnostic lights to trouble shoot the system. Additionally, you can use an outdoor reset control, injection mixing control, or a two boiler staging control. For your convenience I have attached a submittal data sheet, and a typical wiring instruction sheet. Incidentally, all of these controls are on the Taco, web site at www.taco-hvac.com. Please advise, if you require additional assistance.
    Joe Mattiello
    Joe Mattiello
  • Weezbo
    Weezbo Member Posts: 6,231
    go for a taco:)
    Zone esp, taco 504exp, 702 all nice and green use a taco bronze body for the secondary injector you will be looking clean.
  • hr
    hr Member Posts: 6,106
    I like
    the Taco's also they are SWEET :) Not sure I agree with the bronze body, however. What's up with that Wheezer??
    I like the Grundfos 15-58 for most circ applicatione. Quiet, 3 speed, 3 year warranty. And they work fine with the Taco relays :)
    hot rod
  • Vinnie Smedick
    Vinnie Smedick Member Posts: 14
    Definitely a multizone relay like Argo or Taco. Neatens the job, eaisier to install, wire and service
  • Weezbo
    taco bronze?
    Gronfoss? i like them too. just doing a Basic Visualization of a clean Taco no running around system for a happy home owner.
  • Weezbo
    gotta roll..
    3 story 85X40 just called and i been promising that soon as i get out of last year I'm on it! clunky blue meany in the boiler room now gonna caravan with tekmar lose the B&Gs go gronfoss tekmar pump cycler on those.suggest a water maker ...definitely go tiger loop, spirovent,:) maybe drag out the rehau or wirsbo to remote hot water line and up grade the hot with a tidy re circ. old timer friend will really like it:) especially the riello burners and the fuel bills:)
  • Weezbo
    boiler choise?
    thinking of some slant fins:) on stands:)i'd like to sawzall the room clean first buh....down time consideration :( like way many zones.
  • hr
    You need to chat with Noel
    our resident Slant Fin guru :)
    hot rod
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    You could also consider...
    a Honeywell R8888B1005, a four zone circ control panel with priority, status & diagnostic led's, can be expanded up to 16 zones. Works with any Honeywell or competitive stats, check it out at http://hbctechlit.honeywell.com. I think you'll like this control!
  • Jim_44
    multi zone relays
    thanks to all for your advice. i will be looking into the relays you suggested.
    Weezbo and Hotrod-- I dont know what you were talking about.
    Jim
  • Jack Smith
    Jack Smith Member Posts: 53
    multi-zone relays
    sorry not a great quality picture, but the pumps are wired into the panel
