Water hammer
kevin coppinger_4
Member Posts: 2,124
to have a water hammer( 1 bang) at start(cold) up and then be quiet for the rest of the cycle? I have an in stall that the customer is conserned...It did it before and after the new unit went in....kpc
re ; hammer
Check the pitch of the piping,you may have a low spot causing a small amount of condensate to pool and go bang on start-up.0 -
I agree
with water being hung up in a main pipe . Another reason would be no insulation on the pipes - once they heat up , no more banging . We had a problem job , a Burnham commercial steamer . Nothing but nightmares till the owner finally insulated all the pipes . It solved ALL the problems - banging , low water/boiler overfilling , and short cycling - all stopped happening . Good luck Kevin0 -
Hi Kevin
Missing insulation can do that, too.
Water in a radiator...where is it that it bangs?
Is it a snap, like water and steam collapsing together, or a bang, like water hitting a bend?
Noel0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
