Leaking pipes
Fladin
Member Posts: 1
Need help please.
My wife and I purchased a home in New Jersey last year built about 1900. The house is in very good condition however one of the feeder pipes in the basement has a hole and is leaking whenever we turn on the heat. It is heated by a gas furnace and the area where the pipe is leaking is near the heater. Last winter, one of the many pipes finally burst, producing an opening about the size of a dime spilling water in the basement. Needless to say we called a local plumber who replaced the pipe. However, there is another leak forming near the first one with the same result. This all started when I notice small rust spots on the first pipe. Appericate the advice given, thanks.
A picture may help. It's hard to picture what you're explaining. It sounds like you maybe need some more of that steel pipe replaced...0
- 87K THE MAIN WALL
- 57 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 990 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
