commecial gas water heater
jim f
Member Posts: 182
i have a customer that has a 199k btu 85 gallon rheemglass gas hot water heater that is leaking. this unit provides a church with hot water. kitchen with 3 large sinks, commercial dishwasher,4 bathrooms. church is frequently occupied.
i am looking for opinions and suggestions on some equipment for this load.
thanks in advance
jim f tri-cityheatingandcooling
thanks in advance
What state you in
It depends.0 -
southern ct0 -
hot water
Jim, worked down in your area for a while. How do you do it?
Seriously, look at tankless gas units. A perfect application for high demand on a limited basis.Churches typically use facililties 1-2 times a week. Storing lots of hot water when not needed simply isn't efficient. Rinnai makes a great tankless unit as do other manufs. How about the heating system? Can you tap that resource?
right now it is set up on a coil with the large steam boiler. coil is corroded and not useable.summer time valves are supposed to be shut off and isolate water heater... no one knows what to do to change it over... i want to give the customer options and let them make thier decision.they also need extensive boiler work, oil tank repiping and pontentialy a 15-20 ton multiple zone a/c system to this 1860 historical church.0 -
Come on Al,
> you do it? Seriously, look at tankless gas
> resource?
> _A
> HREF="http://www.heatinghelp.com/getListed.cfm?id=
> 248&Step=30"_To Learn More About This
> "Find A Professional"_/A_
Come on Al,
You miss Ct.
Keith0 -
sizing programs
Hello: Rheem and the other manufacturers all have sizing programs that might help you select the right heater. Don't just match what's there as heaters are often oversized. I'd check out the equipment in place and determine the maximum flow needed to see if tankless is an option. If you do use a tank type heater, hook it up with side plumbing so you have easy access to the top to change anodes and keep it going.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
