News from B&G - Dan H.
BELL & GOSSETT INTRODUCES NEW ISOLATION FLOW CONTROL FLANGE
Morton Grove, IL.March 1, 2004 - Bell & Gossett" has introduced Check-Trol', a new isolation flow control flange that combines the features of a flow control valve, isolation valve, and companion flange in a single valve.
This three-in-one innovation offers multiple benefits, such as delivering minimal pressure drop, an advantage when one considers the losses that can be experienced when a check valve is installed internal to the circulator. Additional benefits of the new product include a full port ball valve that allows the circulator to be removed without draining the system; an internal spring check prevents gravity circulation and flow in the wrong direction; and a free-floating companion flange provides for easy alignment and makes pump installation a snap.
Available in 3/4", 1" and 1-1/4" NPT and Sweat models, the Check-Trol (patent pending) is designed to be used with all major brands of circulators, including the Bell & Gossett NRF, NBF, and SSF wet rotors, Series PL, Series 100, HV, PR and LR circulators.
Bell & Gossett
Bell & Gossett, a unit of ITT Industries, is a leading manufacturer of centrifugal pumps, circulators, hydronic specialties, heat exchangers, and packaged systems for variable and constant speed pumping, heat transfer and pressure boosting. For more information contact Bell & Gossett: 8200 N. Austin Avenue, Morton Grove, IL 60053; phone 847/966-3700; fax 847/966-9052; or visit www.bellgossett.com.
Retired and loving it.
