Tankless for radiant floor
Fetzervalve
Member Posts: 7
It appears that most/all tankless heaters can modulate their burn - is it possible to control this for use in a radiant floor app with outdoor reset or do they only modulate based upon flow rate?
Flow rate
Based on flow rate with most. Did a reset job using a tekmar injection control to run the pump that takes the heat out of the tankless. Just have to keep in mind what head and flows you need to work around0 -
We use the tankless
heater all the time for a radiant or HWBB zone.
E-mail me and I'll send you the schematic diagram of the piping arrangement. Reset is nice - but not necessary.
