diverter tee problem
[Deleted User]
i recently had to cap off a radiator on this system.. this system circles the basement of the house with diverter tee's for the radiators.. i capped the two lines in the basement, bled the radiators and everything is working fine, except they called me to tell me they heard the water flowing through the pipes a little loud through the house.. the temp is at 160 and the pressure is at 10 lbs... any help? thanks
Is you want to eliminate the noise, remove the caps and run a parallel pipe between the tees or remove the tees.0 -
As UniR said
NEVER "cap" lines in a diverter Tee system. If you have to disconnect a convector, you sholud put a cross-over pipe between the two tees.
Try it, you'll like it!!!!!!!!
Mark H
